While the car is just sat there, I'm going to clean then engine (inside and out)
I'll use some ecotek de-coking spray for the inside, I'm just wondering what to use for the exterior.... I was thinking of a rag and some WD40 might do the job!?
Steam cleaner is always good!
followed by a can of silicone dressing...thats how i did mine looks peachy......
I have used WD40, but was advised not to use it on the rubber stuff as it could react, don't know if that's true! So I use a rubber cleaner (from Autoglym) for that. :thumbsup:
Naaa its fine to use WD40 on rubber stuff....after all its a silicon based lube
I use "gunk" .. found half a can in the house ..
Theres a new product out called 'JIZZER' lol, its pretty cool you spray it on, go over it with a stiff brush of some sort and then as its water based you can hose it down and all the crap drains off - just make sure you dont do it on the driveway because you'll be cleaning that too!!!
Matt.
just outa curiosity if i wer to do what u just sed matt. Use the !Removed! :o then hose it off what bits in the engine bay would i need to cover w. a plastic bag (or equivalent) so as not to get em wet and damage em. I'm already thinking fuse box, induction kit, what else m8?
-Z
most improtant thign to cover up is the dizzy cap i think, apprently it becomes a SOB once it gets soaked :arrgg-matey:
Err and alram sirens....cos they dont like water either!
