How Do I Reset Oil Change Needed Light
hi to all just done oil change and filter change on my emina 2.2 td 1993 l reg
any help with how do i reset oil change needed light
were is reset located how do i do it
thanks david in nantwich cheshire u.k
Dude, on your clock cluster you will see a little rubber plug. Take that off and get a nice long thin something e.g. a skewer stick or the inside of a pen. Push this in that hole and into the little button that you should see on the clock face. Hold this down for a second or two and there you have it. Job done.
  • 1 year later...
I just ignore mine till it goes off again but that's a top tip, gonna see if it works for the coolant level low light aswell cus that ones annoying me now.
