Supra Custom
skimber
i need to know if any body knows any reliable garage that can do some work on my supra around the hampshire area stuff like changing back seat , window tint any clues ????? :huh:
Changing a back seat is a 10 min DIY Job. My advice would be to junk it to save weight, - its useless for sitting in! (if you have legs)
If you can tint a window on one car you can do it on anything, you don't need a supra specialist.
Changing back seats?
All you need to do is pull them up from the front. They just clip straight out.
To change the backs you just undo a bolt at the base at each side and one at the base in the middle.
Total time to remove rear seats - 3mins
Tools needed - 10mm socket
:thumbsup:
I thought it was 12mm :P ;)
