Headlights
Jamy197g
Hi Guys,
My Ns Headlamp has been misting up over the last few weeks and yesterday the bulb went after only changing it a couple of weeks ago. I checked and the connector has melted and disintegrated after taking it off the bulb. Now I need to change the Headlamp Unit but dont want to pay an arm and a leg at Mr T, so does anyone know how to renew these? Im thinking the Bumper has to come off? If so, how easy/awkward is this?
The bulb I had in was Phillips extreme Vision which were brill. OS one is still working fine and no misting whatso ever....
I am thinkin to put a replacement unit in which is not an original...Any thought on this?
Any help would be appreciated.
Hi Guys,
Try the dealer, seem to remember if its less than 5 years old and 100K on the clock Mr T will foot the bill, nothing to lose by enquiring
Hi Guys,
hello
Yes mine had also the same issue in 2007 with the same melting reason.
But I was forced to change it by MrT. It was right side headlight unit.
Cheers/Igor
Hi Guys,
hello
Cheers/Igor
Thanks for the response guys...
Sorry I forgot to mention that the vehicle has does 108K now so Toyota wont honour the replacement under Warrenty.
Anyways, I took the car to an auto- electrician yesterday and he stripped the wiring and extended them and put two new connectors on for me. It took him about an hour and charged me £25 :-) better than paying out for a headlight!! Also I found that after leaving the headlight casing off for a day the condensation disappeared although some dry residue left on the lens..
By the way, can I leave the casing off? Im just wondering if it starts raining, is there any chance of water entering it?
Also- the electrician saved the bulb ( they cost me £30 apair) by sandpapering the bad terminal...They work fine now!
