Headlight Problem
yas1230
Hi Guys,
Got a problem. Yesterday my left headlight bulb went. So i replaced it. The full beam works, but the dipped headlight doesnt work. Fog lights are ok. Can anyone help?
Yas1320
Hi Guys,
Yas1320
Check if you have a feed to the bulb (test light or voltmeter)
Then if so, make sure it's not just a dodgey new bulb.
Check you have a good connection onto the bulb terminals. (no corrosion or blackened terminal in connector block)
If no feed to bulb, check fuse.
Hope this helps.
Hi Yas,
Had the same kind of prob a few weeks ago, took it to auto electrician and the connector had a bad connection. Turned out it had melted the connector and damaged the wiring. techniciandid a little re-wiring with new connectors to sort it out...
