Rear Seat
Phillgb
Dont know if anyone can point me in the right direction , one of my rear seats wont slide back , looking at it the pull bar is not lifting one side all the way up , is it easy to remove the bottom cover to gain access or is there any other way to get at it .
There are two silver sleves one each side and on the jammed side it hits against a tag ( metal) that sticks out ?
Drop the seat back right down and push it back up again so it is slightly reclined backwards. If that doesn't work try moving the front seat forwards and allow the rear seat to go further forward before trying again the seat back method and giving the rear seat more room to come further forward during the process. Keep your fingers out from underneath!
The seat needs to go through the full movement before the mechanism will "reset" itself for sliding back.
PS Would you mind adding a bit more detail to your profile so we can see what model you have. I'm presuming this is a 4.2 as we've had this before.
Yep that did it thanks :D
