i all
need a bit of help
my surf as suddenly started to play up ,ie the speedo has stoped working & the o/d off light keeps flashing , also the brake light is on when the handbreak is fully off but when i decellorate the light goes out
has any one had this happen to them ? or knows the problem and how to solve it
thanks ,Dan.
Check that the alternater is working and that the fanbelt is tight.
HI ANDY
WILL DO
thanks for the reply.
the volt meter on the dash shows it is 12 v does that mean the alternater is ok ?
No, you need to get a meter on to the Battery terminals to see what the voltage is at the terminals.
Hi all
sorted the brake light problem :rolleyes: :D :D
next is the o/d off dash light & the speedo any one any ideas ??help needed
thanks all , Dan..
Hi all
tested the batterys &the altenator, fan belts, all ok
still need help any one an idea :crybaby:
getting desprate now
  • 3 months later...
Hi all
Could be the Speedo sensor. Back of the gearbox by the output to the propshaft.
  • 4 months later...
Hi all
have the same problem, but when I rev to around 1600 rpm problem dissapear... will check 2morrow...
Hi all
OK I did a test:) charging 12.92 - 13.9 V seems to me that 2 belts are bit too loose, the same air con one, will try at first to set a proper tension on belts maybe will work. Read somewhere that is a possibility to adjust a voltage regulator does anyone know how?
another update... :) brushes ok, but diods gone on the back plate.. does anybody know how to check that voltage regulator is ok? mine is 80A...
