Yaris 99 Engine Noise
lukbeat
hi, I have Toyota yaris (vitz) 99. I noticed that during acceleration, there is noise from the engine for some time. I investigated it and discover that if I put some lubricant or grease on place witch I marked on picture the noise disappear. Unfortunately after one or two days noise appear again. I suspect that the bearing is gone. Can you advise am I right and if it's possible to change the bearing myself? regards, Lukas
