Engine Lag
astrob0y_
hi,
my gen 7 celica has a problem when i step on the accelerator, it takes a few moments to rev like a lag.
it only happens when taking off cos the problem is at low revs.
when i tap the accelerator it jumps a bit then a second later goes higher.
hope that makes sense.
any ideas what it could be?
thanks,
kelvin
sounds to me as if you have air intake or slight timing issues that are just a bit out to cause lag when you accelarate.
Check air filters / breathers easy stuff etc. as a starting point
if this dont help maybe have it plugged in on diagnostics ?
cheers
Keith
