Engine Management Light
Imran adam
:angry:
Hi all,
Engine Management light keeps coming on wit the same fault!
changed the fault
still on .......
Could it be the ECU
toyota avensis 2000 model
2.0 Diesel Turbo Not a vvti :(
:angry:
Hi all,
changed the fault
still on .......
Could it be the ECU
I would suspect you haven't cured the fault. Fault code points in the right direction but is not always the specified unit that is at fault, could be a faulty connection/wiring to the unit.
For example fault is EGR open circuit, could be unit itself or a broken wire to the unit.
