just bought a 1996 lucida 2.2 td auto, and on the way back from picking it up witch was a very long way. the engine light came on (not flashing). there seems to be no change in the way it drives, but it is a little worrying! as it was a privite sale. i have a friend who has a the means of pluging it in, but carn't find the port, can anyone help with this?
cheers alex
cheers alex
The diagnostics port is under the passengers seat. You need to jumper TEI and E1 and then turn on the ignition and read the flashing sequence of the engine light this will give you the error code. It will be two parts with a pause in between.
cheers alex
sweet thank you, thought i was going mad . try to find it didn't even think of looking there.... cheers
cheers alex
right done that, and think it come up with a code 14.... 1 flash pause 4 flashes... ingition signal.. got a haynes mannal for pre 95. it says no igf signal to the emc 8 times in succession . but i dont think that it even stopped doing it
. igniter circuit, igniter or emc.... how can i solve this?????? out side a garage
