Indicator Relay Rav 4.3 2008
airhoguk
As the title says any ideas where it is behind the dashboard. Thanks.
Welcome to the club
It is up behind the dash on the driver side and it is a pig to get at.
see attached
flasher.pdf
Many thanks Anchorman, just what i needed
No Problem.
The easiest way in is with the instrument panel out. There is no speedo cable holding it back so it comes out quite easily. It will save you having to lie on the floor trying to reach up - see attached.
meter.pdf
