i have a toyota hilux surf ssrx (LN130) ive replaced the rear drivers side baring and the vibration noise continued have been told it is the diff because it goes quieter as you relese the throttle dont know if anyone can help
I would check the propshaft joints.
thanks for the reply pal the uj's are completly smashed are they an ars@ to change i would llike to give it a go as ive just done the timing belt and rear
baring and seal and all was well till this any advice as the mechanic will do it for £60 with a press
