hi all i have a toyota previa 2.4 1996 the oil light keeps coming on and i was going to start by changing the oil pressure switch but i am unable to locate it as i have not been able to find a manuel can anybody help me thanks
What do you mean you can't find a manual????????? There is a Haynes and Chilton manual available for the Previa's. Pressure switch is close to the oil filter like on ALL cars near the oil pump. When did you last change the oil??
i changed the oil about 6000 miles ago the chap in my local mtr shop said ther is no manuel avail for previa
The chap was talking out his rear orifice. Take a look on Amazon or eBay. The Chilton is the better of the two. I also happen to have the official Toyota manual that the actual service agents use, but these are hard to come by.
The oil MUST be changed every 6000miles so you are due another. If you are using it as a taxi then every 4500.
