Ordering Some Ice Stuff.
Got my eye on a CD/MP3 player jobbie but I need to know if I need:
Wiring adapter.
Facia (DIN) adaptor thingymajig.
If so, where can I get one?
You da man! Cheers!
your welcome ! :D
you need...
Facia adapter FP-11-00
Harness Adapter PC9-406
Ahem, it's the PC9-406 for the 'active/superlive system'.
Or the PC2-17-4 for the non-active system.
And the DIN pocket is actually an FP-11-01.
Look Here
(ignoring the fact that it says Toyota Supra for the DIN pocket, just look at the pic)
ok... but I used the FP-11-00
How do I know if I have active speakers or not?
Pull up the lid of the storage compartment that's behind the passenger seat, if there's a sub in there then you have the active speaker system.
Jimlad, the FP-11-00, looking at the picture of one of these, I can't figure out how it works - I mean the hole in the top part doesn't look DIN shaped, so how does the headunit show though? *I is confused*
da da... like that.
Doesn't give 100% perfect fit into the dash, but I'm getting a double din unit v soon anyway.. so not that fussed. Will do for now.
Was quite tricky to get the stereo to sit flush.. had to drill holes.. then expand them a bit etc ( on the adapter ).. but got there in the end.
Drill holes?
My din pocket didnt require any faffing about...neither did the Stereo install??
Can you explain what you had to drill holes for?
Drill holes?
The facia adapter was a universal unit.. meant for a few cars etc.
The holes on it didn't match up with the holes on the side of the stereo, so I drilled holes in the facia adapter to match those of the stereo.
Ahhh rite!
The autoleads one slots straight in with no worries...you were confusing me there!
...I drilled holes in the facia adapter to match those of the stereo...
YOU actually did some work!... Stop lying jim, u went straight to CRD and got them to install it didnt u...
-Z
Looks good Jim, I still don't understand how the top part of the fp-11-00 in the pic in the link I posted could allow a headunit to fit through.
Anyways, my DIN pocket isn't quite 100% flush, but 99% is good enough :)
I tried to look under the storage compatment but couldn't get into it... it was dark and raining though.... maybe I just had to pull harder!.... there is, however a storage box behind the driver seat with nothing in it.
-Z
lol.. thought about it !!... na not really... it's about as adventurous as I'll get.
Going to attempt to install my engine start button sometime soon... now that should be fun.
It does need a bit of a tug to open it, but it will open.
So I need this;
And my MD player will just slide in above it I presume?
Amd this;
PC2-17-4 Harness Adaptor Lead
Toyota 4-Runner - Oct 1993 - Aug 1996
Toyota Amazon - Feb 1997 - Onwards
Toyota Avensis - Jan 1998 - Onwards
Toyota Avensis Verso - Sept 2002 Onwards
Toyota Camry - Jan 1987 - Onwards
Toyota Carina - Mar 1988 - Dec 1997
Toyota Celica - Feb 1990 - Onwards
Toyota Colorada - Aug 1996 - Onwards
Toyota Corolla - Aug 1992 - Onwards
Toyota Landcruiser - Mar 1988 - Onwards
Toyota MR2 - Apr 1990 - Onwards (without active speakers)
Toyota Paseo - Mar 1996 - Onwards
Toyota Picnic - Jan 1997 - Onwards
Toyota Previa - Sep 1990 - Onwards
Toyota RAV-4 - Jun 1994 - Onwards
Toyota Space Cruiser - Mar 1983 - Aug 1990
Toyota Starlet - Aug 1985 - Jul 1999
Toyota Supra - Aug 1986 - Dec 1997
And this is all I will need to install my kenwood MD player myself? How come the adapter for the active setup it £7.95 and the one for the none actice system in £29.95!?
John.
Yes, all you need is the DIN pocket (FP-11-01) and the Harness Adapter Lead (PC2-17-4 for the NON-ACTIVE SPEAKER SYSTEM, or PC9-406 for the ACTIVE SPEAKER SYSTEM).
I thought it was the PC9-406 that was more expensive!!!
I bought my PC2-17-4 from Halfords for around £12.
Got my DIN pocket from Halfords too, bit pricey at £29.95 (around £20 at many online places).
Here's a good link too for removing the dash (don't get scared by the picture of the millions of wires that this guy had to patch up - you won't need to with the Harness Adaptor).
Link
Excellent, that's exactly what I needed.
Will my ariel still pop up with an aftermarket headunit?
and also, what's this?:
The big brown side part with the screws.... ?
This is probably the hardest headunit I've ever replaced.... :wacko:
I might spray the centre consol whilst it's out.
The ariel will indeed still pop-up when you select 'radio' on your headunit (that's something I was unsure about before I installed mine).
The 2 brown side bits, that is a 'cage' that screws into the car behind the dash - basically, your headunit doesn't 'slide' into a gap behind the dash, it'll be bolted to it via the 'cage'.
yeah it is already attached to your existing stereo
