Avensis Loss Of Power Whilest Hitting More Then 3000 Rpm
MOUZY
HI THERE, I HAVE GOT A 2003 TOYOTA AVENSIS 2.0 D4D, WHEN IT IS COLD OR HOT IF I DRIVE THE CAR UPTO OR MORE THEN 3000 RPM IT GOES INTO SOME KIND OF SAFE MODE WHERE IT WILL NOT LET ME GO OVER 2000 RPM WHICH MEANS I HAVE TO SWITCH THE CAR OF AND THEN START IT UP AGAIN AND THEN WORKS FINE.
BUT WHEN THIS HAPPENS NO SMOKE COMES OUT OR ANY NOISES LIKE THE OTHER FAULTS I HAVE SEEN IN OTHER FORUMS.
THE ENGINE LIGHT STAYS ON ALL THE TIME WHICH I HAVE GOT CHECKED OUT AND GIVES OUT THE ERROR CODE P1251.
WHEN YOU DRIVE THE CAR ITS LIKE THERES NOTHING WRONG BUT ALL OF A SUDDEN IT DIES!!!!
I HAVE CHANGED THE FUEL FILTER, AIR FILTER, OIL FILTER, OIL AND STILL NO JOY
TURNED THE LIGHT OF AND RESET THE MEMORY BUT KEEPS COMING UP WITH ERROR CODE P1251 AND DOESNT SHOW WHAT THE FAULT IS.
ANYONE CAN HELP OR GOT ANY IDEAS WHY THIS IS HAPPENING??
THANKS.
THANKS.
hello
firstly you'd decode -- ERROR CODE P1251 for additional info.
cheers/Igor
THANKS.
hello
cheers/Igor
HI THERE, I HAVE TRYED THAT ATLEAST 10 TIMES AND REST THE MEMORY, ITS ONLY GIVING THE ERROR CODE P1251 AND NO OTHER INFO WITH IT. THANKS
THANKS.
hello
cheers/Igor
hi
the problem remains the same -- you do not know what to do unless it will be decoded !!!
cheers
THANKS.
hello
cheers/Igor
hi
cheers
HI, I GOT IT DECODED AND GIVES OUT THIS (P1251)is correct it translate to that the electronic throttle motor might be in limp home mode.?? WHAT DOES THAT MEANS
THANKS.
hello
cheers/Igor
hi
cheers
it means that it is necessary to service it by means of cleaning + lubricating.
because it is responsible to prepare (petrol/air) mixture before ignition.
cheers
To MOUZY,
P1251 denotes air mixture solenoid circuit malfunction. Throttle motor just below engine coolant temp sensor just below inlet manifold from memory. Wait for more postings to confirm, you should get a few more postings later in the evening.
Regards, Beagh.
To MOUZY,
Regards, Beagh.
THANKS MATE, I WILL WAIT FOR MORE POSTING THANKS ANYWAY,
HI THERE, GOT THE CAR INSPECTED BY TOYOTA AND SAY THAT THE THROTTLE BORE IS NOT CLOGGED AND SAY THAT THE TURBO VANES ARE STICKING.
BUT I HAVE REPLACED THE TURBO LAST MONTH AND STILL SHOWS UP TURBO FAULT:S
ANYONE KNOW WHAT TO DO ?
THANKS
Hi Mouzy,
Have you had the latest ECU upgrade? Apparently the car goes into this safe mode you describe under certain conditions when it shouldn't. The upgrade merely changes the software settings for the tollerance levels before you get this error code appearing.
Might be worth asking Mr T if this is applicable to your car (it was to mine a 2.2 d4d - not that I had your problems though)
I assume you meant to say that the TURBO VANES ARE NOT STICKING .. (?)
Regards
S
Hi Mouzy,
Regards
S
HI, I DONT THINK THAT THE ECU IS UPGRADED BUT IL ASK MR T THANKS ANYWAY AND MR T SAYS THAT THE TURBO VANES ARE STICKING FOR SOME REASON AND THE WHOLE TURBO NEEDS REPLACING FOR £1250 SUMMAT, YOU GOT ANY ADVICE ON GETTING A TURBO AGAIN OR GET THE ECU UPGRADED? THANKS ANYWAY FOR YOUR ADVICE :)
To MOUZY.
Are Toyota suggesting you purchased a duff Turbo? Vanes sticking, remove your inlet pipe & check for movement that may denote worn bearings.
Go to www.btnturbo.com. They stock just about every brand of Turbo you could care to mention, you may find you have Garret-Turbo ( may stand corrected ) use their catalogue facility to verify your turbo just select 2003 book in PDF format & select your car, also all turbos have info tag that can be cross - referenced against parts catalogue. You may well be able to purchase new or rebuilt turbo with warranty at reduced price.
Regards, Beagh.
PS: Or as suggested check out ECM update if you find Turbo to be O.K.
To MOUZY.
Regards, Beagh.
THANKS FOR YOUR YOUR TIME MATE, I AM GOING TO CHECK IF ECU NEEDS UPDATING IF NOT IL CHECK OUT THAT WEBSITE OUT, THANKS ANYWAY MATE MUCH HELPFUL.
