Which Pads Do I Need
JimM169
The front pads on my wife's Yaris need replacing but I can't work out what size pads I need.
The car is a 51 plate 1.3, it has a JT chassis code, 14" wheels, 235mm discs and ABS can anyone confirm what size pads I need or even better which of these are the right ones
http://www.brakes4u.co.uk/supersearch.asp?...mp;pMake=TOYOTA
Jim
If you want original Toyota try Parts-King: http://toyotaownersclub.com/forums/index.p...c=92588&hl=
Otherwise have a look at EBC or Mintex.
http://www.ebcbrakesdirect.com/car/parts_p...9+%282001%2D%29
http://www.mintex.co.uk
You can normally pick both the above make of pads up for a good price on ebay.
Thanks for the links but it doesn't really help me, I need confirmation of what size pads to order not where to get them from.
There are 2 sizes listed on all the sites for ABS vehicles one size for 99-06 vehicles and a different size for 01-06 vehicles. I'm hoping somebody can tell me the correct size from the spec I've given. I don't really want to remove the pads to measure them as I need the car and wouldn't feel comfortable replacing the worn pad - unless someone can confirm this won't cause any problems ?
Cheers
Jim
According to this site size should be 116 for Jap built 1.3 with ABS: http://www.japarts.co.uk/shop/?sh=search&a...91&search=2
So you want be these: http://www.ebcbrakesdirect.com/car/parts_p...29+%2899%2D%29#
Brakes4u are EBC pads so you want DP1295 for original quality or DP21295 if you want uprated pads. Just ring Brakes4U or EBC up and ask them to confirm before you order.
