Squeeky Clutch Pedal
forty
hi has any one come across this tried wd 40 goes for a day and comes back
cheers forty
Try WD80, it's twice as good (joke, 40--80, twice as good? never mind). But seriously,
You could try some spray grease instead or something like GT85 (ptfe) spray. Or better still can you get in there with an old fashioned oil can?
cheers forty
thanks will try can only help
cheers forty
The usual cause of a squeaky clutch is the pivot point on the clutch release fork. This is inside the bellhousing. Get someone to operate the clutch and listen with the bonnet open to confirm this. Removal of the rubber boot around the fork gives better access. You should then be able to reach with a finger and smear some lithium grease around the pin. If you use a spray be careful and only use a little to aviod any getting on the friction surfaces.
