Hub Removal
c3lic4 k3z
jack up the car,
remove the front wheel
unbolt the brake caliper via 2 large bolts on the back
slide the rotor off
remove the axle nut (i think its like 28 or 29mm)
unbolt the Rack and Pinion (steering) by removing the cotter pin and then undoing the nut, use a hammer to tap the joint out.
Loosen the 2 large bolts/nuts at the top which hold the strut to the knuckle but do not remove them
remove the 3 nuts on the bottom ball joint from the control arm
support the knuckle with 1 hand and remove the 2 large bolts connecting it to the strut
you can now remove the knuckle/hub assembly.
The hub + bearings are pressed in so you'll need to take it to a shop to have the hub and bearings removed/replaced
