Gurgling Sound
The Jackal
Hi All,
I have a Gen 7 (post face lift) GT and noticed an odd noise I seem to be getting.
Basically in you imagine the centre console of the dashboard then further towards the engine bay I can occasionally hear a gurgling sound, a bit like either water sloshing about or water going through your heating system at home!
I've run the aircon for a while in case it was that as it's not really been run much over winter, nope still there!
I have noticed its after cold start and I've been going fast (70mph) for 5 mins then come to a crawl through traffic. Maybe brake fluid? Although not really braking hard.
I've checked fluid levels and they all look good.
So any ideas?
sounds like trapped air in heater matrix system
may just want bleeding to rectify or try running with heater on which if blowing hot may move airlock and disperse into header tank
