Lockable Wheel Nuts
bus
Did this model come with a lockable wheel nut on the spare tyre, as mine does not have one?
Hi and welcome. Can't answer your question myself but there will be somebody along who can. I don't even have a spare wheel :(
My wife's 2001 NRG has a lockable wheel nut on the spare :wacko:
The lockable nut does come with a little cover to make it look like a normal nut, also it's possible that you've lost one of your nuts at a service and they've used the one off the spare :rolleyes:
Amazing the qualifications of these Toyota Techies now. Is it done under general anesthetic? :rolleyes:
Agree with Duncs. My old VX certainly had 5 locking wheel nuts. Think there were a total of 3 nuts (inc 1 locking) holding the spare on.
I've still got the brochure. Don't have access to it at the moment, but when I do, I'll try and remember to check if it makes any mention of the nuts on each trim level, just for completeness, but I can't see why it shouldn't be any different. Fairly certain they were fitted on import or at the dealer before delivery.
EDIT:
Yep brochure shows locking wheel nuts by default for all models.
My model has a hard wheel cover so I am not sure it is the same on the models you mention.
Thanks all the same.
Shouldn't make any difference as far as I know:
On RAV number 1 I use the standard alloy makers wheel nuts. On RAV number 2, I have 5 wheel nuts on each wheel and 3 on the spare, all of which need a sized allen key to unlock nuts.
