Rav 4 Mk2 Window Problem
RAVCLAN
Hello,
We were wondering if anyone could give us a little help/advice please?
Our 3 door 02 Rav 4 has a problem with the driver's side window. It goes up when you press the window button but once it reaches the top of the door it automatically goes back down again. The window motor does not struggle and the button does not appear to be faulty as it responds as it should do.
Thank you.
Just a silly question from me. Have you tried holding the switch fully up manually (don't use auto) and let it get all the way to the top? Then hold in the fully down position and let it go all the way down? Try repeating that at least 5 or 6 times.
There's a re-calibration to this effect for the 4.3, but it might not be quite so similar for the 4.2. Maybe worth a quick try though.
No doubt a windows expert will be along soon. Personally I stick with linux/debian.
Welcome to TOC by the way. :thumbsup:
Hello,
Thank you for the advice and freindly welcome.
We have just given your advice a try and unfortunately, still doing the same thing.
Regards...
Hello,
We just wanted to update and ask again could anyone help, any useful ideas welcome as we just can't solve this problem.
The window button seems to work fine as does the window motor but when you press the button for the window to go up it seems fine until it reaches the top of the door frame and then it just goes back down automatically, but only half way. The only way to get the window to close is by pressing the button 'bit by bit' until it reaches the top.
We have tried the re-calibration technique with the window button and locking and unlocking the car with the key fob several times, but neither have worked so far.......
regards...
Hello,
regards...
Sounds like the 'Anti trap' system is kicking in [assuming there is one]. There isn't anything wedged in the top groove in the door frame by any chance?
Hello,
Thank you.
This is from the 2008 owner's manual--it may be similar to your 2002:
Jam protection function: During automatic
closing operation, the window stops and
opens half way if something gets caught
between the window and window frame.
If the window receives a strong impact,
this function may work even if nothing is
caught.
If the power window does not operate
automatically or the jam protection
function does not operate correctly, you
should normalize the power window.
To normalize the power window:
1. Push down the power window switch
and lower the windows fully.
2. Pull up the switch until the windows
close and hold the switch for a second.
Make sure that the window open and
close automatically. If the power windows
cannot be operated properly, have it
checked by your Toyota dealer.
Hi SHCM,
do you know if there is top ( physical ) limit switch for the window when it closes? I was wondering if the limit had failed and the motor was now seeing the top of the frame as an obstruction and opening in the same way as it does when something, like a hand, obstructs it?
Yes, my understanding too is that there is a limit switch that should open at each end of the window travel.
Anyway, now I've had spare time, I've sent RAVCLAN some info that might help.
It would appear for the 4.2 that to perform a motor reset, as part of the procedure, the motor should be removed. However, at the back of my mind, I have a feeling that this has come up before and I might be mistaken, but I thought Anchs had a short cut around this. I've never had to do one.
Hello Everyone,
Thank you all for your help.
"three5" that sounds exactly like what the window is doing...is there a way of sorting it out?
Thanks again.
I think ther eare Hall ICs involved with them but in the first instance, squirt some Mr Sheen or similar in the window runners to allow the glass to slide freely.
