Please Help: Yaris Speaker Wires
nish
Hi, I've just installed an amp in my wife's 2004 model Yaris. I'm keeping the standard head unit so I don't loose the factory look and have therefore had to run a set of high to low phono converters which connect to a set of speaker wires. However I'm finding it difficult to identify the front or rear speaker wires on the main radio wiring loom. It doesn't look anything like the ones I have seen on the net.
Does anyone happen to know what colours they are for a 2004 UK model?
Thanks in advance for your help.
Been covered many times before and is in the How To's And Useful Information section above.
passenger side (left channel)
speaker positive = pink wire with silver tracer
speaker negative = purple wire with silver tracer
drivers side (right audio channel)
speaker positive = green wire with black tracer
speaker negative = blue wire with black tracer
Sorry, one more question... Which wire do I connect the remote wire for the amp to?
I tried connecting to the grey one like it says in one of the guides in the useful info section but when i connect everything up the amp and radio stay on all the time even if the key is not in the car. I don't have one of those light meters which I can use to test the wires with the ignition on and off.
Thanks again.
