Auris Driver Back Light Help Needed
navisace
hi all
having a bit of a problem i was trying to take of back drivers side light of my auris and the loom plug was fitted tight so as i pulled it i managed to pull away the wiring from the plug :( :unsure:
problem is i have no idea what order the wires go back into the plug.
there are 6 wires in total and i was wondering if any other owners would be kind enough to look at their plug and list what order the wires are or a photo would do.
thanks in advance
nav
Hello!
Which one is the back driver's side light? :huh:
Best regards, Alex
hi alex
its the one on the right if you look at the car from the back
the same as the one in your picture
thanks
nav
hi alex
thanks
nav
Ah, the answer was closer than I thought :D
I'll try to check it out today if I'll get a change :)
Best regards, Alex
I've checked the wires now and here is the order they're connected in:
If the plug is connected to the taillight which is on the driver's side and
you look at it, the order from top to the bottom is:
Yellow
Light Blue
Red
Black/White
Green
Blue
Hope you'll get your lights working again, please post when you'll get your
problem solved!
Best regards, Alex
@alexC you beat me to it. I was just outside taking a pic. I took the pic in case the UK version is slightly different to the european version.
@ navisace Hope this helps. This is the right/drivers side.
And it looks like there is a slight difference as your top wire is yellow where I have 2 light blues. Then the rest is the same.
The left side:
I believe the difference is in the reversing light and fog light. yours are opposite to ours.
thanks chaps
i'm will go and have a go at fixing it now
will be intouch
thanks again for replys
nav
Yepp I think so too, sorry I messed up with the sides. Forgot where the driver is sitting in your country.
Now I checked it again and on the left it's like I said but on the right (on the side about which you asked navisace)
there's no yellow and the blue is connected higher so there's a gap (two sockets) between the top wire and the rest of them.
Don't have two blue ones... Don't know how it's in your car, but I think you should connect them as they're in wastedagen's
picture :) And now I have soup on my screen, was eating whilst writing :lol:
Best regards, Alex
mmmmmmmmmmmmmmmmmmmmmmmm.............Soup
hi guys
once again many many thanks for the replys :D
its was the same as wastedagen photo. :thumbsup:
fixed it now.
you chaps are the business :angel:
nav
Glad to hear everything's working now :)
Best regards, Alex
