My Exhaust Mount Has Rusted Away Help
TiMiX
Hi all, managed to get my Mongoose exhaust on today and noticed the rear back box mount (on the car) has rusted through :(
Lucky the bracket is bolted on not welded so easy to swop out, its just finding a replacement. Anyone else come across this problem
and do you think Toyota will stock the part at a sensible price :)
To be honest mate if you have a welder just make it yourself or go to a workshop if you can't find the part. I suppose you could just find someone breaking the car you have probably be the cheaper option.
For example
http://cgi.ebay.co.uk/Breaking-Toyota-Celi...A1%7C240%3A1318
Cheers for the heads up, i`v sent him a message :)
Not got a welder, but might treat myself one day.
Tell ya this dam exhaust is loud! :o Didnt think mongoose's were that bad, but that was going back abit.
Is noticibly more responsive though. Going to see if i can live with it, if not a re-thinks in order :(
Didn't you get a bung with it? I got a bung with my exhaust for track days, makes it a bit more quiet
Don't just message him he seems like he is making a business from breaking sometimes better to contact someone doing it on a one off probably get it cheaper.
Good point, i'll have a look round at some others too.
No didnt get a bung, not sure i'v ever see one to be honest :unsure:
Whats it look like and where does it go then? :huh:
ok this is a bung, goes in your tailpipe, should be a hole in your tailpipe where the bolt goes thru to keep it in place
Ah see now, Nice! never come across one before, looks like a handy bit of kit though :)
I have a twin pipe so would need twin bung's if they do that, don't think this one has that option.
Not sure this exhaust was a good move, its loud and hanging much to low which is making it look stupid.
Am hoping the new bracket will sort it. Got one on order with Toyota for £10 which isn't to bad.
Cheers for the bung heads up :thumbsup:
i have the same problem with mine, about rusted away. although i want to get a new exhaust like yourself before im going to attempt to fix it. don't suppose you have any suggestions on what i should get? im after a single not double pipe.
