Another Toyota Boy :)
Misters2
Im Stewart. Im new too this whole forum thing so be nice i became a member because i own a Mr2 1999 model that has a NA 1998cc 3sge in it . I want too put a turbo on it the stock ct20B would put a smile on my dial but its not as simple as that i can get all the parts i need 4 it all ECU, Compressor, oil feed lines, Manifold, dump all that lovely stuff but i need t no whether My Gen 3 motor has the piston oil cooling from factory ??
What else do i have too do ? other than the ovious lowering of compression.
I have done hours of research on these engines i read the only difference between the 3SGTE and 3SGE is the lower compression and of course the turbo ?
Looking at a turbo trottle body its in a completly different set up too the N/A's one ..
Is there a champion that can help me?? Ha !!
S2ii :):) :help:
