Abs Fault
darren.holligan
HI, i have a intermittent ABS fault, the light comes on with ignition and goes off as i should,, the problem is the light comes on only above 60MPH and always after about half a mile, there is a constant point on my route to work where the light comes on every time with the speed and distance measured.
There is no difference to braking and if i turn the igniton on and off the light goes off again as it should until the required speed and distance come into play again.
I have cleaned all sensors and checked the ABS rings, everything appears OK, if i drive aroung town the light never comes on.
Anyone got any ideas, had the same experience, any info appreciated, The car is a 98 2.0 CDX.
Thanks, Darren.
checked the wires for corrison.
HI, as far as i can yes. looking on other forums some suggest the relay, though i tought they either work or don`t. This being a intermitent fault
so the abs light only goes on above 60mph.
have you had a windscreen replaced ?
checked the relays for dry solder joints ?
made sure the srs computer is plugged in firmly ?
Thanks for your replies, i have found the fault !! its in the tyres, i had 65`s on the rear and 60`s on the front both are 15`s, i replaced the fronts with 65`s and the faults gone, i asked on google and it appears you can`t run different profiles on different axles no matter how slight. It appears that at 60 MPH the difference is enough to alert the ABS, in this case.
blimey!
didnt even think of this :lol:
