I Have Gt S185
mrgmonkey
Hi i have the above car imported 1992 and it is standard apart from a stainless steel exhaust system and was just wondering if any1 had any recommendations for modifying it, dont want to go over the top but would be interested in some ideas.
thanks
ST185 GT4 im presuming your referring to?
Decat - helps turbo spool
Induction kit with a heat shield and cold air intake
Boost controller
Fuel cut Defender
Boost controller
Fuel cut Defender
dont no if you should fit th fuel cut defender ive ask the same question on here and ben told to stay well away ??
your better off without one unless your going to fit aftermarket management as the injectors go ino safe mode and run at 100%, which leaves you with an empty tank and wallet not to mention risking bore wash
