How To Remove Bolt From Suspension Bush
Loom
Hi all
I'm trying to change my rear suspension arms (the trailing arms / longitudinal links) but are having some difficulties:
Firstly, one bolt stripped :angry: . Any advice on how to undo the bolt?
Secondly, I can't seem to extract the bolt from the suspension bush. I tried spraying it with WD40 but haven't had any luck so far.
Also, would you advice changing the bolts and nuts while I'm at it?
Thanks again
This looks like a good extraction tool but it's for 12 mm max. Does anyone know where to find a larger one (at least 17 mm)?
I finally managed to remove the bolt by heating it with a gas flame, WD40 and lots of tightening and loosening turns.
