Help - Door Mirror Wanted (and Info On Exhaust)
aaddee
A long shot.... but does any one have a passenger side door mirror for a 2002 RAV4?
The plastic molding holding the mirror to the door is broken, Toyota only do the complete assembly not just this part
also...
All the factor parts dealers I have contacted tell me there is no aftermarket replacement exhaust for the 1.8vvti 2wheel drive RAV4.
They say I will have to buy a genuine Toyota part.
The exhaust for a 2.0l 4x4 RAV4 looks very similar to my exhaust.......anyone know if a 2.0l petrol exhaust will fit on a 1.8vvti?
Not too desperate at the moment but I think we will need one at some time as the flange between the centre section and the back box looks a bit ripe!
Any help welcome.
Many thanks
Adrian
also...
Any help welcome.
Many thanks
Adrian
Have you tried this one on eBay? CLICK Seems to be breaking an '04 SWB
also...
Any help welcome.
Many thanks
Adrian
This place don't actually list a full mirror for your RAV - but it might be worth a phone call: http://www.wingmirrorman.co.uk/wing%20mirrors%20full.htm.
on the exhaust, you can get stainless jobbies made up at a lesser cost! And a decent garage can modify an exhaust if necessary - with both my RAVs, the first is a fully custom made job. The 2nd is the original RAV exhaust system modified to the MR2 3SGTE turbo set up. The difference is mainly noise....the 1st is a straight thru with limited silencing and I think its 2.5" to 3" diameter where the 2nd is the original with all the boxes and what looks like a 2" pipe.
also...
Any help welcome.
Many thanks
Adrian
Thank you all for the advice,
I had seen the item on eBay but some of the feedback put me off the seller.
I did get a stick on replacement glass off eBay for £8 inc. delivery so if the superglue holds on the mounting bracket I should be ok until I find a complete assembly.
Stainless steel system seems like a good option.
Thanks again
I had seen the item on ebay but some of the feedback put me off the seller.
I did get a stick on replacement glass off ebay for £8 inc. delivery so if the superglue holds on the mounting bracket I should be ok until I find a complete assembly.
Thanks again
The only problem I had with my stainless system was it cracked towards the rear - but that was cos it was hitting off the rear on the standing 1/4 mile starts!! I got it repaired/replaced for free. Stainless steel is more rustfree but is also a bit more brittle - just in case you intended going serious off-roading!!
