Verso Very "jumpy" When Cold
We have a Verso which is a 57 plate and we are pleased with it apart from one thing. When the engine is cold the car is very jumpy for the first few minutes. Has gone back to the dealership who couldnt find a problem - they made it sound as if it was normal but I dont think that a car made so recently should suffer from this problem. I had a R reg ford escort years ago with an automatic choke and that didnt do it! Any ideas or comment would be very welcome.
Hi
Welcome to the club, could it be the same problem as this thread....
http://toyotaownersclub.com/forums/index.php?showtopic=94364
You don't say if it's the petrol or diesel, I have the 2.2 diesel and have to say it is fine and smooth when cold, it is down on power when cold, I drive it nicely until it warms up anyway, but I have had to boot it when cold and it does seem a bit lethargic, maybe the ecu does this to protect the engine...
There is also an ECU reprogramming talked about on here, it's done by Toyota under warranty, usually at service time...
Have you had the car long? Has it just started this?
Pete
Hi
Thanks for the reply. We have had the car since October and its petrol and it has done it since we first had it. It only takes a few minutes to warm up and then its fine but every time we drive down our road on our way out we can feel it - it feels as is you have taken your foot off the accelerator for a split second - if that makes sense. But its not a smooth ride for the first few minutes.
Thanks.
Hi
Pete
Hi
Can't say I'm afraid, my mate has a petrol one and his is fine so this is not normal.... keep moaning at the garage untill they fix it..
Good Luck
Pete
If the dealer believes the behavior is standard for the car you have I would ask them if you could test drive a car of the same spec to compare them.
Thanks for that - is going in for a service so will have a go.
Hi
Pete
hello there i have a T180 and mine is the same when cold mainly in first and second gear . also does yours still do it when engine is warm reason i ask is had a bit of a near miss at a roundabout. had to pull away a bit quick but car didnt want to move . then when the revs picked up a bit the car flew off
