Jammed Passenger Door
krip2454
My rear nearside passenger door seems to be permanently locked.
There is no way I can shift it.
Does the door locking system have individual relays for each door and if so, does anybody know where I can find them, or indeed any ideas on how to fix it at all?
Presumably it wont open from outside or inside?
No
No
You will have to get the inner trim off the door and get in there to open it. Once it's open, you can investigate the cause. Sounds like it is jammed in the deadlock position or maybe something has come adrift from the mechanism.
