Abs Code 36 Testing Rear Left Sensor
Hi thanks to the great resource of this forum I have managed to diagnose my carina E 1.8 gs R1997(the proud new owner of it - it's an excellent drive)
Code 36
Open in right front or left rear wheel speed sensor circuit. Check speed sensor, sensor rotor, wiring harness and connector.
Can't get the rear sensor out, the gent at the garage reckoons I can get a reading from the sensor connection at the other end but I can't source the other end ?anyone?
also lats night I got a brutal grinding noise coming from, driver side engine front, but, but for the first time ever the ABS light went out for all of 60 secs ?coincedence?
what next?
I have scouted these boards but unable to find a cinclusion to this prob
thanks in advance
just want to add this to perhaps help others with similair prob
sourced this diagnostic pdf it's for a camry but it certainly helped me
http://camrystuff.com/manuals/Gen4/Diagnostics.pdf
when I did a fault reading I got a code 36 which suggested front right - however when I took OHM readings it turned out to be front left
I sourced a sensor from the scrappys I took out both front sensors from a 95 celica
(it was a Bosch like mine but the top fitting was different - used a wire juncton box and now ABS light is out :yahoo: off to book my MOT now
That was a good file you linked too, thanx.
Hi, In reply to the rear sensor problem. The connector for the rear sensor is inside the car under the rear seat trim. Various options depending on the model. You need to trace the lead from the wheel sensor to the rubber grommet where it enters the car. Then on the inside remove seat trim to expose the lead and continue tracing to the connector. Hope this helps.
