Changing A Headlight Bulb
faolteam
Why in the name of stupidness Does toyota and most car companies make it impossible to change a simple bulb , i guess i have to b a child to change it,
I have had many blown on me and when i change them its nearly always night time, and i have to put them in mysaelf cause i need light to drive but everytime i do it i make an ***** of it and my mechanic tells me i need the whole head light unit , i seem to pay out more on headlight units than petrol
can anyone recommend any way of putting them in ????
or anywere in Dublin that u recommend
whatever way i have them on now i cant see in front as there pointing down aghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
help plz
help plz
This topic has been aired many times here. I have found the way to change the dipped beam bulbs is to have a pair of long nosed pliers, a flat headed screwdriver and a 10mm spanner. The offside bulb remove the cover by pressing downward on the tab on the cover to rotate it. Note its position and carefully bend the filler tube of the screenwash reservoir back a little to allow the cover to come off. Pry off the connector with the screwdriver and unfasten the spring retainer. Lift out the bulb with the pliers. Fitting the new bulb is a reversal of the above. On the nearside it is easier to remove the Battery clamp with the spanner and lift the Battery a littlet to the left to allow room for your hand. If the light beams are too low lft them by unscrewing the plastic hexagon nut on the side of the unit.
Fitter
