Brake Pads + Disc Question
osmononame
Hi, having just had my car serviced I have been informed that I needed new brake discs and pads - I was going to get them replaced anyway as I knew they were coming to the end of their life. I have priced up the brakes from EBC Direct and they come in at about £280 which is fine but out of that about £200 is just for the discs - would I be better off buying cheaper discs from say eBay or a motor factors (£100ish all in) and use the Greenstuff brake pads (or put the extra money towards some DS2500's or Mintex pads)?
I'm a bit of a n00bie when it comes to brakes so any help appreciated.
hey dude,
ive just replaced my disc's and pads on my st.
i got the ebc green stuff pads (as i got real bad brake fade from the normal ones fitted) and i just replaced the discs with std ones... they work loads better and subsisquently, i havent s*&t my pants due to brake fade :P
i guess it depends how hard you drive really at the end of the b=day, but ive deffo found the green stuff pads with std discs work fine :)
hope this helps!
Hi There,
Just thought I would let you know that I have just changed my discs and pads & brake fluid on my Gen 6 2.0 GT.
I bought drilled & grooved discs of fleebay (Ireland) with Mintex pads all around. Even new handbrake shoes, fitting kits & cables.
The total cost of materials was £220. The cost of labour from the local garage (4 hrs) £150.
The mechanic who fitted them race prepares cars for the Porche GT cup so i new i could trust him.
Eveythings spot on and I dont think the cost was too bad.
I just use my car for going to and from work mainly....Fast road use..
Hope my input helped...
Big E.
