Cleaning Products For Interior Trim
ABZ-T2
Hi guz
Just wanted to ask what products everyone uses to clean the not so popular interior of the auris. I just use soap and water at the mo but its not enough. Used a BACK TO BLACK spray once, did a very good job but left it shiny for about a week. Especially the bottom door trims, they seem to collect the most dirt and scratches.
Any suggestions?
Also just to add does anyone find it difficult to wear and replace their seatbelt. I feel as if theres not enough room between the seat and the seatbelt panel for the belt. If tht makes any sense!!
B)
Someone else on here mentioned a while ago that they use Autoglym Fast Glass, and I've been using that iside the car ever since. It's great for getting the mat finish dash looking clean. I just spray in on and wipe with a synthetic cloth.
That was me... It's just great for most "hard plastic" surfaces, and just leaves them clean and like they came out of the factory.
It's also good for glass too! :thumbsup:
Thnx guys il defo try it.
But isnt it meant to be just for glass? Searched on the net and doesnt say anytin bout usin on plastic. It wont disclour or will it? Has any1 been using it 4 a long period of time?
Thnx again
Whn you pick up a bottle it says on the back what you can use it for. Theres loads but plastic is defo on it.
Hi again
Tried the spray today on one of the door trims. However, it left the spray blotch and dried up drip marks on the trim when i wiped it with a cloth. Took ages getting rid of em with a damp cloth. Is this normal? Dont wanna try it on other surfaces if it aint! Appreciate any advice.
Cheers
