Hi lads, does anyone know if the 1.5 Jap import corolla engine is the same as a paseo/cynos engine? :censor: :!Removed!: :blink::crybaby::crybaby: Help! I want my paseo back!! :crybaby::crybaby: This merc i'm now forced to use is driving me nuts!
Not sure, but I wouldn't have thought so.
the Starlet Engine will drop straight into a Seo though,
What happened to your original engine?
The engine started using a lot of oil, traced to an incorrect oil filter fitted prior to me purchasing the seo! Then it started knocking in the bottom end
:!Removed!: :crybaby: Expensive lesson lads, use only genuine Toyota filters !!!! :crybaby: :censor:
