hi im a newby to site and toyotas and hope someone can give a bit of advise on cos of new kickdown cable and where i can see diagram of how to replace it thanks in antisipation garrybuild
Whilst there is a cable that runs from the throttle body arm to the gearbox it is not a traditional kickdown cable but rather informs the gearbox about the throttle position. These boxes are ECT (electronically controlled) and that cable very seldom breaks. It does however need adjusting from time to time and actually becomes stuck due to corrosion. Some working at it with WD40 from the top is often sufficient to release it.
If you do nee dto replace it you will need to drop the gearbox sump to do the job. Do what I suggest above first.
thanks for reply cable definately snapped can pull it out of sheath , havent pulled it right out but about 2inches was coiled out of sheath and could push back in and pull back out more than 2 inches i am assuming this is cause of judder as gears change at low speeds regards garrybuild
Ok well in that case it was incorrectly adjusted in the first place
You will need to drop the transmission sump. The cable enters through the right hand side of the box. Just use your logic and be patient.
thanks for your help. i presume parts only from toyota dealer, will they be able to tell me correct adjustment for new one?
The adjustment is very simple
On the throttle side of the cable there is a rubber boot and on the cable there is a little solder lump. The forward end of this lump must protrude 1-2mm from the end of the boot i.e. you must only be able to see 1-2mm of this lump protruding from the boot with the throttle closed.
Toyota only as far as I know.
thanks very much for your time and help will try for part today
help just returning from ordering parts for gearbox,stopped at shops went to pull away and could not seemed like slipping clutch on a manual gearbox. managed to crawl home by revving high untill box started to propell car but very high revs untill kicked in as soon as i slowed down again had to start whole process again. do i need new gearbox or will parts ordered cure this would really appreciate some opinion here thanks garrybuild
Doesn't sound good. Check the colour AND level of the oil. If brown or black and smells burned you have a serious issue.
Auto boxes also have clutches and something called bands. The clutches can burn out if the oil is old or the level is too high or too low.
as i suspected, oh well lookes like hunt for second hand gearbox. anyway thanks for help and advise propnut
