Low Idle ! Tempary Or Permanent Cure ! !
Kcs
Hi all, after many hours of trying to sort out the low idle on my
x reg yaris, i gave in and adjusted the screw on the accelerator
cable/ throttle body ! i adjusted the idle speed to about 750 - 800
rpm, this was after a long drive home from work, so the engine
was at its best temp ! i did think this would cause me trouble when
starting from cold, but it is spot on now, it has also made gear changes
smoother, that little bit of extra air has obviously fooled those pesky
sensors ! !
I had the same problem a few years ago and considered doing the same but was concerned it would affect the emissions at MOT time. I did eventually fix the problem by cleaning the MAF sensor with electrical switch/contact cleaner, I followed the instructions on a previous thread (with pictures).
To view the thread type ' P0171 system too lean (bank 1),I need to troubleshoot a P0171 error ' in the search box above.
Best of luck.
Sorry I fogot to mention, choose the post that was started Jan 19 2004 by jeffrenee and go to page 2 then scroll down to post from georgeincanada (oct 23 2006)
