4.2 55 Round Fogs Or Driving Lights?
Notebook
Are the lower round lights fogs or driving lights as a mate said? anyway, flagged down tonight and told to turn them off - didnt know they were on.
They are fog lights (didn't think cars came with driving lights now?) and the Highway Code does advise you when you can use them:
226
You MUST use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear fog lights but you MUST switch them off when visibility improves (see Rule 236).
[Law RVLR regs 25 & 27]
236
You MUST NOT use front or rear fog lights unless visibility is seriously reduced (see Rule 226) as they dazzle other road users and can obscure your brake lights. You MUST switch them off when visibility improves.
There does seem to be different rules for most BMW drivers though... :lol:
The lower lights are fog lights. I don't know about the UK legislation, but Norway has restrictions about the usage. Here you can't use them in combination with the driving lights, unless if there is fog of course. Otherwise you can only use the fog lights when the headlights are dimmed and the clearance lights are on...
A golden rule is that if you see front fog light symbol front_fog.jpg or the rear fog light symbol Rear_fog.jpg on the dashboard, and there is no fog... then figure out how to turn them off, because they are a disturbing the other drivers around you. (and you might get fined by the cops as well)
