How To Reseat Speedo Binnacle ?
topgazza
My Yaris centre (speedo) binnacle/cover is slightly raised from the dashboard on the right side. There is now a gap. I presses down ok bu seems to be seperating from the dash slightly. Possibly heat from the sun warping the dash ? Only 3.5 years old mind you.
Is this a common problem and are there any guides to removing the binnacle surround to try and reseat or stick it down to give me my nice smooth dash back ?
Cheers
Cheers
All you have to do is pull it out it is just cliped in to place
Cheers Stuart....repeating what you said but I just lever it off ? No spring clips to push back or anything like that ?
I'll give it a go. It almost seems like the actual dashboard on the right has "sunk" a fraction but I suspect it is the binnacle that has moved upwards....
