How To Remove Lucida Front Brake Disc Help!
rako
please help how to remove front brake disc , I removed caliper but cannot remove disc :(
check to see if there is a retaining screw which goes through the disc into the hub. if so remove this.
Next i would take a rubber mallet and gently hit the disc from behind so that it comes away form the hub and towards you.
But thats just my advice. Dont hold me responsible for any damage or accidents.
Its always best to pop it along to a professional if you dont think you can do the job yourself.
Check that there is a retaining screw holding it in (not usual for Toyotas in my experience)
If there isn't there are usually two threaded holes in near the disk centre, (usually about 5-6mm) put a dot of WD 40 or similar in there and simply screw in a bolt in each, tightening them in turn a few turns at a time - the disk should then pop off as the bolts push against the mounting plate behind the disk.
It's a more ideal approach then trying to bludgeon them off with impact ;)
