hi guys i have a blacktop toyota levin 99 20v 4000km back i fitted timing belt kit + i had the cam shafts off also to fit 20 cam followers. i then fitted the small toyota filter and changed the oil. since this i think the vvt hasn't bin workin i double checked the timing and al the other day and it al perfect any ideas. could i have fittin cam shaft in wrong position or is that even possible. or could it have bin small filter that did the damage. i checked thr resister in ecu and it seems perfect, any help really appreciated. SQ
  • 9 months later...
the cams got disturbed so check the vvt pulley, also the timing might not be correct, you could have bad oil pressure as well.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
