Rav4 2008 Blaupunkt
Jukka
Hi
I have Radio/CD unit of Toyota 58827 in RAV4 D-4D 2008 Cross Sport model.
I want to change that unit to my old Blaupunkt New York one DIN Radio.
Is there a kit (chassis and wires) for this kind installation in Europe to be sold?
Thanks,Jukka
You'll loose you steering wheel controls (if you have them)... unless you can get hold of an interface adapter. I don't know anyone that carries them, but you can just google it.
You also need a wiring harness to convert from Toyota to ISO connectors.
I think the easiest way would be to look at Biltema, and search for item nr 31535 which would be the correct one for you. However, if you live far away from a Biltema store, then most car audio shops carry these wire harnesses.
Never cut the original connectors in your car! I've seen several people doing this, and it will make things worse for sure!
