Avensis 1998 S Reg
Casey
Hiya, I want to change the Speakers that came with the car:
1. I am not sure what the size of the existing one is.
2. Can someone please fill me in on speaker product that will give me a bigger sound than the factory fitted one without buying amplifiers(even if there is need to, any suggestions)? I am still using the Sony WX-C570R Double Din that came with the car. This unit has 4x35W Power Output and i think 35 ohms (not too sure)
My budget is within £70 :-))
Many thanks for your help.
Casey
Hiya, I want to change the speakers that came with the car:
Casey
Changing the Speakers wont give you more volume, the power output of the radio controls that. You will improve the sound with better Speakers but not the volume.
(More likely to be 4 or 8 ohm speakers)
The power output of the radio is giving to the Speakers is only 35W even if the Speakers are 75W you will only get 35W.
The power output of the radio is giving to the speakers is only 35W even if the speakers are 75W you will only get 35W.
Cheers bruv. This means i must have an amp. if so what Speakers type and capacity do you think will serve me right and what amp?
Casey
1.the existing size is 5.25 inch
2.35w per speaker is total power of the unit not RMS,so it,s probably more like 12w.Too increase the volume and sound quality you will need an amplifier.I would recomend something that will give you at least 50w RMS @4 Ohms.
Hope this helps. :rolleyes: :D
