Sequential Auto
todger
Hi
Can anyone give me a brief explanation of Sequential Auto as opposed to regular Auto.
TIA
Todger :rolleyes:
Hi
TIA
Todger :rolleyes:
Hi mate if you are referring to the likes of Toyota multimode type transmission here is an over view of the system:-
The multi-mode transmission is the development of a standard manual gearbox, with gearchanges actuated by electric step motors and an automatic clutch. It is linked to an electronic drive-by-wire throttle and dedicated sensors, ECU and shift lever.
The transmission offers two driving modes: automatic (E) mode and manual (M) mode. The former provides the usual ease and convenience of an automatic transmission, but it delivers better fuel economy than a conventional manual gearbox as the system’s shifting map selects the optimum gear at all times and takes into account driving conditions, throttle opening and vehicle speed. In the latter mode, the driver has the option for more dynamic driving and the use of a sequential manual gearshift.
Hope this is what you are looking for .... Pete.
Hi
TIA
Todger :rolleyes:
I agree with what Pete said.... I have to as I did not fully understand it ;) :lol:
Seriously though.... I have had two sequential auto boxes in the past, both were Nissan with the Constantly Variable Transmission (CVT) My new Avensis will have the same set up :D
I like the CVT as it gives an unhurried constant delivery of power and it is always in the correct gear :yes: But.... when you switch it over into the 'manual' mode and change gear yourself then it can be a lot of fun :driving:
If you are thinking of buying such a set up then I must recommend it :thumbsup:
