Enter The Cabin
supafly
I can't find the nipple thing to connect an amp to the Battery? I heard it was on the passenger side bulkhead, but wheres that? Is it inside or under the bonnet?
:thumbsup:
there are 2 nipples, follow the wires from the Battery to the fuse box, then into the car
theres a massive black gromit with a hugh bunch of wires going through it on the bulkhead just behind the Battery
i cant get it thro the big one im struggling to get hold of it once its thro i have big air con tank in the way
Toyotas have spaces for loads of wires like the ones in the door sils, the space to run the cables thru is massive. You can fit a truck thru that gromet in the bulkhead with a bit of :ffs: u :censor: ing :censor:
If u know what i mean
lee try feeding a small 'fish wire' through the gromit with the aid of a screwdriver or somat to push it through then feed it into the passenger foot well.
stick ya hand up the back of the dash and have a fertle round for it ya should be able to grab hold of it
then tie ya power cable to the fish line and pull it through
:thumbsup:
should be there??? then again i cant be sure they are on all yarii?
