Brake Noise!
teekay523
i just got a garage to install a new set of ebc disc and pads all round yday. now the brakes seem to work fine but when i turn the car left( high speed and low speed), there seems to be an awful scrapping noise coming from either the right front disc n pad or read disc n pad. is this normal due to the fact that its still in the bedding in period cause previous disc and pads have not made this sound at all. please help if anyone knows the answer!!!
TK
Hi, it could just be that the back/splash plate is catching the disc , you could try pushing it back a little through the gaps in your wheel to see if it helps, but if it worries you I would take it back to the garage for them to take a look.
