Cool Running
Bronwyn
I own a 92 Previa 2.4 auto petrol, the miles are high, 208k however it's been very well looked after by the previous owner fmdsh. However for the past couple of days it's been running a bit cooler than usual. There doesn't seem to be any difference in the performance and it's not causing any probems to the heater. Sometimes the revs go up and down between 500 and 750 when it's ticking over, but it's been doing that for a while. I've had a look at what i think are obvious places and nothing seems to be wrong. Has anyone got any idea's? :(
The most likely cause is your thermostat is stuck open. As your entire cooling system will need to be drained to do this I would advise that you have the system flushed before draining. This gets rid of a lot of the rust, lime scale etc that has built up over the last 208K miles and should see you get uite a few more miles out of it. The thermostats itself is cheap enough but make sure it comes with the rubber O ring.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
