Hi there, I have a T180 06 reg that has done 38k, its just coming up for its 1st MOT and the handbrake needs adjusting, its pulls right into the sky.
I have seen a previous post for an 05 reg : http://toyotaownersclub.com/forums/index.php?showtopic=74467
not sure if this is the same, as it mentions the gearstick on the centre console? and my 06 has the gearstick on the bottom of the dash!
Anybody know how to do it for sure?
I have a 06 T180 and I also needed to adjust the handbrake, as in the previous posting I adjusted mine at the hub, and it worked fine. I think the mention of centre consol is a red herring as that is what toyota the bottom of the dash. It took about 30 mins to do the job once you remember which way to turn the adjuster. :D
